Spring eye hitting rear hanger
Back in Chandler, AZ
I have a 1978 FJ40 with 3" Black Diamond spring lift and stock shackles. Springs have full military wrap. Under compression, the rear spring eye will contact the spring hanger and is leaving an indentation in the hanger. Will extended shackles cure this issue? How long? Other options?
I really don't want to lift any higher or have to use spring shims to counter act the change in caster from longer shackles.
Where did you get the 1" extended shackles? The closest to 1" that I have seen are MAF 3/4" over stock.
You could just get some 1/4" thick x 3/8" wide material and make your own. That's what I did when I had to get longer shackles when I installed my FJ55 rears. You can weld a center piece in or leave it just to the two sides like the Fj40 shackle.
PabloCruise said:
Weeny,
how do you like your Downey's? Did that work pretty well w/ your Scout PS?
I like the Downey's they drove pretty nice on the road. I did use RS9000's tho so that helped quite a bit for the dampening. It work fine with my scout p/s, it does not get in the way like a SOA does. I now run a bump stop so that the springs don't run into the pitman arm when flexing up.
