Spotlight Question
Orlando, Florida
I'm toying with the idea of installing some 7" spotlights in my bullbars. My question is - will doing this greatly impact the airflow through the grill and thus cause overheating issues?
I've seen a few threads on this topic. The answer appears to be a definitive "maybe". Some people report overheating issues after doing anything to obstruct air flow. Other people seem to report they've completely filled the front of their truck with lights and no effect on cooling. Do a search if you want to see who was on which sides of the discussion.
Thanks Blade, I did a few searches before posting but nothing relevant came up. I'm guessing if I lived further north it would be a moot point but down here in SoCal we can pack a few extra degrees in the summer. Last thing I want is to cook my motor at a set of traffic lights.
I think it depends on how far away your lights will be from the grill
My search came up with fewer results than I'd anticipated. Search Results for Query: overheating lights obstruct | IH8MUD Forum[node]=9 Not nearly as hashed and rehashed as I thought. If you get a bunch of replies, I still think you'll get all the answers from yes to no (and the maybes, in between).
I also suspect it has to do with how far from the radiator the lights are placed, and perhaps the size and shape of them.
These are fairly on topic for you.
Lightforce 240's on an 80....are they too huge?
Winches and other junk in front of rad: engine temps!
i have the same concern as well. i have the generic arb winch bumper with a warn zeon 10K winch installed. the control box is mounted on the lower light tabs so it sticks up in front of the radiator. i then put 2 7" round LED's hanging down from the hi-lift mount tabs, so i've got a good bit of stuff blocking the air flow. i did the light install a few months ago, so it wasn't super hot. so far, using my scan gauge II, i haven't seen any change in the temperature. the big test will be next summer, but so far its ok.
You will be fine. If the lights are affecting your cooling system, then the system probably needs attention anyway.
I suspect this is mostly the case.
At nearly 20 years old, even the youngest 80 series is likely to have an original cooling system that is somewhat degraded in capacity if still on the original radiator.
Installed an ARB and XRC12 soon after purchase. Found that running the license plate in the mount provided with the ARB that puts the plate upright just above the fairlead caused some issues. Noticed it getting a little warm the summer afterwards, so got clips to move the plate down to cover the fairlead. This held for several more years. I suspect lights would've caused a similar lack of cooling from time to time.
2 summers ago, the cooling issues were creeping back. After doing a fan clutch upgrade with mixed success, found that the radiator needed R&R for partial blockage. That solved the cooling problem once everything was dialed in. Haven't moved the LP back up or added lights, but probably would not be an issue now.
So if your truck has a marginal cooling system, the lights or whatever may cause you grief, but it's likely a clue that you need to pay some attention to the cooling system if it does.
Only one way to find out for sure...
Thanks guys. My radiator looks newish but I don't have any service history to confirm when/if it was changed. I think I will stick on the lights and see if I can measure any rise in operating temperature. Down here we never seem to be more than 10 days away from 85-90°f so I won't have to wait long for results.
