spool?
Fresno, Ca
Website
www.4x4him.com
I think I read a post about how Texican modified a spool from a 10bolt to fit a cruiser?
does anyone know anything about how to do this?
I was going to weld my rear, but the carrier had already been broken and welded and couldn't weld the spiders.
Any info on this would be great. Thanks!
Jason
Jason
Urban Legend.........
OK, the true story is, I watched "W" from Cascade Cruisers install a modified 12 Bolt GM in one at CM 02, according to him, you have to polish the parts that go intp the carrier they are slightly larger than the Toyota units......I have really been itching to order one and do it, just for kicks, they are only $100 from Randy's RG & P......you know the part on the side gears just outboard the thrust washer? This is what needs to be smaller....... :flipoff2:
Pin_Head said:
Ummmm,
What kind of side gears do they run in the spools they have in Texas?
:flipoff2:
I was making sure he knew what part had to be turned down.....dick head........................oops Pin head........ :flipoff2: :flipoff2:
This place makes me feel more at home each day. Thanks guys.
As mentioned someone on here must have an un-used carrier you can pick up for little or no $$$.
