- Joined
- Jan 8, 2006
- Threads
- 266
- Messages
- 9,823
- Location
- Ashland, OR
- Website
- www.jeffersonstatecruisers.com
No problem, thanks for the work "Man"!
[B]33482-39135[/B] 18 tooth, 18x6 mark VZN105/VZN110/VZN13*
[B]33482-39025[/B] 19 tooth, 19x6 mark TCR1* (MTM)
[B]33482-39045[/B] 20 tooth, 20x6 mark RN106/RN110/RN13*
[B]33403-29125[/B] 32 tooth, 32x10 mark RN10*/RN110/RN13*
[B]33403-39345[/B] 31 tooth, 31x11 mark RN131
[B]33403-19255[/B] 32 tooth, 32x11 mark RN10*/RN110/RN13* (MTM)
[B]33403-29115[/B] 33 tooth, 33x11 mark VZN10*/VZN110/VZN13* (MTM)
[B]33403-39295[/B] 18 tooth, 18x6 mark TCR11
[B]33403-39305[/B] 19 tooth, 19x6 mark TCR1* (MTM)
[B]33403-39315[/B] 20 tooth, 20x6 mark VZN110/VZN13*
[B]33403-29315[/B] 32 tooth, 32x10 mark RN101/RN110/RN13*
[B]33482-39135[/B] 18 tooth, 18x6 mark RN10*/RN110/RN13*
[B]33482-39045[/B] 20 tooth, 20x6 mark RN106/RN110/RN13* (ATM)
[B]33403-39345[/B] 31 tooth, 31x11 mark RN131 (ATM)
[B]33403-39295[/B] 18 tooth, 18x6 mark RN10*/RN110/RN130/TCR1*
[B]33403-39305[/B] 19 tooth, 19x6 mark TCR10
[B]33403-39315[/B] 20 tooth, 20x6 mark VZN110/VZN13* (ATM)
[B]33403-39425[/B] 32 tooth, 32x11 mark RN10*/RN110/RN13*
[B]33403-39415[/B] 33 tooth, 33x11 mark VZN10*/VZN110/VZN13*
I just regeared from 4.30 to 4.10, so obviously my speedometer is 2mph off. What I do know is, I have a 20 teeth speedometer gear and I will need a 19 teeth one to match my axle ratio and tires. I looked through the parts catalog and see that the VZN85 uses a 19 teeth speedo gear. Does this fit on all the other runners (that has an automatic) of the same era regardless of engine? I thought about using a 18 teeth also, but that'll make the speedo slightly fast. I don't want that! Anyhow, if the speedo gears in the 90-95 mini truck/runners mix and match, does anyone know where I can find these cheap (other than junk yard or dealer)? I would love to have an accurate speedometer again![]()
