Speedo cable
i have had good luck with white lithium grease, you can get it in spray or tube. i am sure others will chime in.
I have used all purpose to no ill effect. I guess they make speedo cable grease as well.
I would have to discurage the motorcycle cain lube, it has a tendancy to be sticky and may cause lag to the dial. Regular usage of a lightweight lube or oil on a monthy basis can help the issue, lithum greese is good if you pull the entire line lube it and re-install it.
KY is always a good choice! :D
Accel cable is about the only place I WOULD use white grease. I steer clear of it on all chassis parts.
