Anyone know a good trick to hookup the speedometer cable to the instrument cluster. I'm afraid I may have to disconnect it from the trans. to get enough slack in the cable to make the connection.
get out your die grinder and make a small notch above the cluster. that will give you a bit more room to make it all come together.Anyone know a good trick to hookup the speedometer cable to the instrument cluster. I'm afraid I may have to disconnect it from the trans. to get enough slack in the cable to make the connection.
With the cluster tilted forward just enough to sneek my hand in, I can reach in and click my speedo in. You should also be able to reach from under the dash, left of the steering column. That is, unless you have aftermarket goodies in the way![]()
If I tilt enough to get my hand in there isn't enough slack for the connection. I may just have to disconnect the cable and try to re-route.
I think this is an OEM 76 speedo cable. I don’t recall buying a new one. This rig did get converted to a chebby 327.View attachment 1670879
Just left of the clutch. Should be a spot you can reach up in.
I'm about to try to reconnect my cable also. Having never seen the end that attaches at the dash does it just sorta snap onto the speedo ?
