Speedo Cable Help
Western WA
So I have a 91' LC with a noisy speedo cable... I have got the dash apart and the instrument cluster loosened up; however, the cable is so tight behind it that it's preventing me from being able to pull the cluster out to the point where I can get in behind and disconnect the cable.
Does anyone know of an easy way to do this?
Thanks!
Look at the left side of the transfer case. :meh:
Edit: I'm starting to worry that you don't know what/where the transfer case is. Apologies if that's not the case.
Er.. is this something I can get to from inside the vehicle? Or do I have to go under it to disconnect the cable?
I see the speedo cable - where it goes into the tranny-area hump..
Let us know if you replace the cable. I may need to do this soon.... mine is pretty noisy.
Will do, I'll take pics too and post em'...
Er... just noticed your FJ80... drool..................................
Why do so many folks pick those plack wheels? Is there something good about them?
I just wanted cheap steel wheels since I couldn't fit my NEW tires on the OEM ones. They were about $50 a piece and I liked the black....
Ahh.. okay.. just seen lots of folks using that same style of wheel.. wasn't sure if there was some advantage to them for off-road and such..
Okay.. so no pictures...
BUT .. I found a great place called Tacoma Speedometer - they built me a brand-new one for only $40bux...
It took them about 20minutes to make it and they even cleaned up my instrument panel for free!
I'd highly recommend these guys, you can find them at:
Tacoma Speedometer - Home
In the future, if you simply unscrew the cable housing from the transfer case, you can pull the actual drive cable out of the sheath without doing anything else. Clean it up with the solvent of your choice, coat it with a nice layer of moly grease, and slip it back in. To seat it correctly in the speedo, simply spin the cable until it finds its way home. Screw it back on to the transfer case and you're done.
I just puled mine, super easy. Greased it back up and the Speedo has stopped bouncing. :clap: 15 min job tops. It didn't take my sounds away though...still searching...maybe they are in my head.
