While coming to a stop the GX gave a little shudder (like the ABS activated) and then the ABS, BRAKE, Traction Control, and triangle warning lights came on with a check BSM system message. On the way home the warning lights went off. Then, after 100+ miles, same thing...shudder at low speed while coming to a stop and the same lights are on.
OBD Link MX+ reports C1403 Malfunction in Rear Speed Sensor RH Circuit, C1407 Open or Short in Rear Speed Sensor RH Circuit, C1415 Rear Speed Sensor RH Circuit Output, 2x C1A45 Vehicle Speed Sensor codes (and a P1605 Rough Idling and B15EC, which I assume are unrelated).
While I was rotating my tires, I pulled the passenger rear speed sensor and it was clean (looked OK). I took off the electrical connector, which looked good with no corrosion, etc. There were no obvious issues with the wire along the rear axle.
Lexus dealer replaced the pads, rotors, and brake fluid a year or so ago. The brake fluid is halfway between the min and max lines in the reservoir.
Is there anything I can do to troubleshoot/repair this? I now live about 100 miles from the nearest Lexus dealer and I haven't checked to see if the local Toyota dealer would do any service.
