Specific brake ?
here
For those who have disc on front using GM 1/2 ton calipers( not monte carlo)and original ( 2 whl. cyl.) drum rears , did you get a good pedal after bleeding or did it still have to pump 1 time ? It is bled good and still requires 1 pump then if you stuff em the rears lock up . I feel if I adjust rears in to prevent lock up it'll just cause worse pedal and more pumping to get good pedal.
Will a proportion valve fix this ?
I have a late 70 fj40 with stock vacumm boosted MC and stock rear drums.
Fronts are 1/2 ton chevy calipers with 1 " rotors. The caliper piston does stick out a little to get tight and this could cause the spongy pedal due to the volume needed to move piston out that far but would it not stay there when pedal was released?
The proportioning valve should help out with the rear lockup problem but it won't help the spongy pedal or having to pump the pedal. If you are sure you have all the air out and the rears are adjusted correctly then you are not moving enough fluid. Only 2 ways to do this - You need to have a longer throw or a bigger bore MC.
You can also make sure you have the pedal adjusted all the way up with the rod to make sure you are getting full throw with waht you have now but more than likely you will need a larger bore MC.
A '75 FJ40 Drum/Drum MC is 1" bore. That's the biggest Land Cruiser MC I know of. You will have to remove the residual valves from the front half if you use this one.
The '78-FJ-45 pickup uses an 1-1/8" bore master cylinder....that is what I have been using for some time on my truck. I am using 1/2 ton chev calipers all the way around, which are larger than the smaller gm metric/Monte caliper. My pedal is firm with little travel, and the brakes work great.
Good luck!
-Steve
O.K. Poser , so you got 1 for me ? or even the 75 1" ?
I did not remove the residual from my 70MC and it does not seem to be draging. I would like it if someone had a 78 fj45 MC with the front residual removed ? anyone ? Kurt , Steve , anyone ? Hum , ya think Mudrak has one ...........
