speaker size
Finland
What is the diameter of J9-series front (door) speaker? Will 5 1/4" fit or even 6½"?
I've got pioneer 6" in mine
Regards
D.T.
They are 6.5", rear too. I changed them to 6.5" component system.
Original:
New:
There happens to be just right size space for crossover unit under door panel. [:)]
Is this the same size for front and back in a 5 Door Prado VX??????
Looks almost as DLS. In that case: Good ****!
Is it hard to access the rear speakers? How easy is it to fit new onces to the front? Bolt-on?
//Mattias
You have to remove rear plastic side panels before you get to access to the rear speakers. Quite easy, easy after you have done it once.
Front ones are from Biltema (you know because you are from Sweden). I put some spacers between them + some modifications to door panel ring (the spacer thickness off of it with knife).
