Does this apply to the factory amp common (or shield)? Grounding to similar locations or just ensuring good grounds is always a must, but I think the problem here is that you can't easily ground the factory amp common wire going from the head unit to the factory amp. It is not the same as chassis ground as that offset seems to occur internally within the amp.
Sent from my XT1060
I am talking aftermarket headunit and aftermarket amp. Not sure about factory wiring.
