Spark Plug Analysis
Central Oregon
Spark plugs out of 1977 2F. I put these in like a year ago, not a lot of miles - maybe 1-2000. Anyone have an analysis? Ordered from front to back. #2 looks the oiliest.
Number 1 lean….number 2 and 5, oil foul….best guess….
You need a picture looking down onto the center electrode.
And after miles of various driving conditions, reading the plugs is questionable. Best method, buy a new set,,,,go find an empty road….change plugs next to the road…..then 2 full throttle runs up 1/2 mile and back 1/2 mile….then pull and read.
Be good…..see ya at the drag strip….😎😎😎😎
#1 appears to be good. You need better pics. The ceramic around the center electrode is an important factor. I dont believe that style plug was originally used in a stk engine. What's the compression #'s.
I still need to do a compression test...good tip.
Dry and wet compression test numbers will tell you more. I would pull the plugs on a hot engine and then give each cylinder a spoon full or two of marvels' mystery oil - bump the starter to distribute the oil, let soak for a few days - goal try and free up the rings.
Cool, just going into town so I can try this today when I get back.
Verify plug gap as well. Old ones look excessive.
My 2 cents. Oil fouled is ring related. Lean is a vacuum leak unless they are all that way. I spent weeks working a spark plug break down tester. Even new plugs could have the spark blown out at like 60 psi. A properly adjusted plug with a squared edge would often fire at 150 psi the limit of shop air pressure.
I'm not a fan of black box ignition. Been stranded way to many times. Points, yes I have had to adjust them. Only once in 60 years of driving the points arm broke off ( on a state highway dept dump truck) and it was stranded - they would not let me carry any spare stuff other than for the unique road testing equipment we used.
I had them gapped higher (close to .50) for an HEI distributor - bad idea?
0.50” or 0.050”? Normally 0.032-0.036” standard distributor on an F/2F motor. I use around 0.045” on my SBC 283 that has an hei dizzy. Your picture above looks a lot more than 0.050.
I mistyped, should have been 0.050...
They look better, but still think you might take a look at 6, looks a little oily. Does rig use any oil? 1/2 a quart now and then?
Maybe a compression check is in order.
I agree, compression check on a wsrmed up engine. Your plugs show inconsistencies. Do all dry 1st, then sqirt some oil into the cylinder your going to check next.
Yeah, I need to go get a tester, been meaning to do that. The inconsistencies I saw were why I posted...thought it must mean something.
It doesn't consume a lot of oil, but there's also leaks. I haven't really tried to quantify the amount lost per mile because of how infrequent it gets driven. The intention is for it to be driven more though!
