Yeah I had mine up there on a trip or two, no big deal. Some pretty good wind noise comes from the rack itself (especially if you run the top rail !!) ...But unless you install a wind deflector just about any cargo situated towards the front of the rack makes a ton of noise.
Oh, be sure to use the rubber strip that fills the front channel or you will get even more noise from the rack.
Its not a problem anymore for me` cause I cant hear anything over those swampers![]()
personally, I would not put a spare up there unless you have a guardrail around the roofrack or tire
may i ask as to why? to prevent it from sliding off? to protect it? how come?
Sin,
Which Swamper do you have?
My first tires on my truck was SSR 35x10.50x16 and they SUCKED! Other than than the noise but they sucked in rocks (Moab) - rain - sand (Pismo) - dry pavement well .. Did I say they SUCK?![]()
I would not mount a tire to the roofrack with straps. AO has a tire holder, but I am not keen on it. The AO rack allows for things to be bolted down pretty easy. I would make a tire holder to accomplish this.
Tire+wheel combo is anywhere from about 70lbs+100lbs. Why put a spare on the roof and dramaticly increase your center of gravity?
Questions for those with the AO rack:
Should I go with the half or full rail?
Anyone have experience with the new black color? Is the finish just as durable as the silver?
Thanks
Macneill, you didnt show up at carnarsie pier! we could have put it on there, there were guys swapping wheels and all kinds of madness. Neways...good luck tommorrow and post pictures when your done!
but, if you already HAVE a rear bumper, couldnt you just do a dual tire mount? Personally i would rather throw two tires on the back then one on the top n one on the back.
