Well, if you had a problem with the truck idling before, without the choke pulled, that's a good sign either the ICS or, more likely, the ECU was malfunctioning. Honestly, to simplify things, you're probably better off just deleting the ECU and the all the other smog bits and running it that way, particularly if you're not going to have a CAT conv. Jim C will ground the ICS on the carb you're having rebuilt, if you want to go that way. Let him know.
However, @Engineer8000 may have a remaining tested/repaired ECU should you want to keep it and the 'Deceleration switch' and circuit.
