Source for rubber bushings?
Atlanta
Website
www.prequel.agency
It's amazing how much better you can see - and how much worse things look - when you're standing under the truck on a lift. Now that the suspension is done, I want to replace some other worn bushings - the sway bar for example. I know. I know - the cool thing is to just ditch it. Nope. I like sway bars. I'll pull it at the trail head. For the street, this tall, narrow truck on 33s needs all the don't-sway help it can get.
I found a few sources for poly bushings, but would really rather have rubber. Partsouq and a couple other online parts sources came up dry. Any suggestions (other than ditch the sway bar)? Am I getting too picky?
thanks!
@gnob I hadn't checked Dorman - thanks. They do have at least some of the parts. And @liveoak that eBay link may round out what Dorman doesn't have.
The (small) challenge is first getting the right part number - lots of sources will say "Fits 84... Pickup" but won't specify the 19 or 24mm diameter sway bar. Dorman does provide that level of detail - BSK74269PR is for the 24mm bar.
