I was wandering if anyone has used the remote oil filter lines from SOR. I just purchased a set and am having problems with the fitting that goes onto the motor and regulator. The factory fitting has a significant taper and turns in easy by hand. The ones with the hose kit has maybe a slight taper. I can only turn in maybe a 1/4 turn by hand and maybe one turn with easy pressure on ratchet. It just doesn't seem like the fittings are correct and I certainly don't want to mess up threads on engine block. I would imagine someone has encountered this so hopefully someone can share some direction. Reached out to SOR yesterday for help but so far no one has gotten back to me. Thanks
