Some trouble down shifting.
Check if the clutch is dragging or if the pilot bearing is siezed:
With the truck parked and the engine on, step on the clutch and put the tranny in reverse and out to N and back in reverse. If it makes a grinding noise each time you go into reverse, either the clutch is dragging or the pilot bearing is bad. Adjust the clutch (lengthen the adjustment rod at the slave) and try again.
Hey just my .02 cents but isnt the 3 speed non-syncro 1st gear? if it is that would prolly make a BIG difference for someone to shift who's not used to it, and that would make a huge difference going from 1st to 2nd vs 2nd to 1st. Like I said just my .02 cents
