I just installed a new Koyo and I started thinking about a few things. I was talked into Toyota Red antifreeze and I am glad I did so. But it got me thinking. The only place you can get it is Toyota. I noticed a small leak on one of my intake hoses (I will get into that in a minute) but it made me think about being on the road if something like that happened. I know I cannot mix Prestone, or Green antifreeze with the Toyo Red. So if I am out in the middle of nowhere, I will have no choice but to fill the rad with distilled water if there is no way to fix the leak on the road. It seems to me that by using Prestone, it is a good insurance policy since it is available in most auto parts stores. But I know it is not as superior to the Red that is designed for the car.
As for the leak, I used the original press release hose clamp. I am losing some fluid there and I need something tighter. Is it bad form to reuse those clamps for this very reason? I would hate to go to a screw clamp. Are there better solutions?
Lastly, I know the F80 rad takes four gallons of fluid. I was only able to get just under 3.5 gallons in the radiator. I drove around for a while and turned the heat on so the thermostat would open up, but I did not need to refill. I was hoping there was some air in the line somewhere but every time I check, it is fully topped off. And before you ask, I fully flushed the system multiple times including once with coolant line cleaner. I drained by unplugging the bottom hose and removed the block drain. I filled the radiator while running the engine.
