Some Driveline questions
Germantown MD
History: 1995 w/ 120k miles. new to me in march of this year, I have new 75-90w in both diffs and mobil 1 in t-case. Transmission has been topped off with amsoil. No complete knuckle job yet. Coming soon.
paper work from the previous owner shows amsoil drain and fills for the tranny, greased u-joints and diff /t-case fluid changes. PO also has a reciept for new seals for knuckles, doesn't say which seals or what else was done.
Issue:
I have a faint mechanical type of noise that is hard to describe coming from my front end. Like gears turning, very faint, not noticeable until vehicle goes above 50 mph.
I went through Landtanks front end check up procedure and found nothing out of the ordinary. The drive shaft/u-joints on the vehicle had no play in it and has been recently greased. Wheels had no play in them either.
Tonight i pulled the front drive shaft and none of the u-joints had play, then I locked the CDL in 4Lo pulled the fuse for the CDL, back to Hi, and took a ride to see if the noise was still there and it was.
The sounds reminds me of the sounds my cousin's FJ60 makes when in 4Lo. Is this normal in an 80? Am I just being paranoid? This is my first 4x4 vehicle so a lot of this stuff is new to me.
Other observations, one of the u-joints, the one connected to the front diff feels like it has more friction that the others. the others were very smooth and moved under their own weight, meaning they moved when positioned against gravity. The one in question did not, but moved smoothly when moved by hand, is this normal?
I had read about the drive shaft greasing procedure and how some people found the the grease was not penetrating the shaft.
During my first lube I used red grease in all the u-joints and 3 pumps of grease in the drive shaft to see if it would reach the yoke. When I pulled the shaft I could see red grease on the yoke, however, when pulling the shaft out there was suction. Nothing I couldn't overcome by hand but it was present. Is this normal? There was also some resistance and what sounded like air hissing when I cleaned up the yoke, re greased and put it back in. What do you guys think?
Sorry for the long post, I tried to research everything in order to diagnose.
good that you took the time to clean up the driveshaft as long as you had it off.. I too had a very similar noise in my front end, would start in around 55-60, then get higher pitched the faster I'd go from there. Would only be present when I was on the gas, if coasting it would go away. Same for you?
When I regeared the noise went away completely.. so call it worn gears, worn bearings in the third, loose pinion, whatever since it all got replaced. You could try changing gear oil to something heavier for an experiment, or something lighter, just to see if the noise changes. But I drove mine for 4 years like that, never really got worse..
turning up the stereo and/or installing big tires also made it less noticeable... hth :)
Not exactly what I wanted to hear but thanks for your input. I was hoping that it was something more along the lines of a loose bearing or a bad u-joint. Could it still be a loose bearing even though the wheels show no signs of play?
Any thoughts on the drive shaft air hissing on compression?
[snip..] When I pulled the shaft I could see red grease on the yoke, however, when pulling the shaft out there was suction. Nothing I couldn't overcome by hand but it was present. Is this normal? There was also some resistance and what sounded like air hissing when I cleaned up the yoke, re greased and put it back in. What do you guys think?
I just replaced my U joints so I can comment on those. My new U joints were stiff. I am not quite sure if they would move under their own weight but they would not flop around like the worn ones. On the other hand, I also had a couple of U Joints that were seized up in one direction. So...as to weather yours is a problem or not is hard to tell. It depends on if that stiffness in your U joint is due to very little wear or is due to a U joint starting to sieze. U joints are typicaly all replaced at the same time so I would say that U joint was dry or going bad. I probably wouldn't replace it right away but I would keep my eye on it and check it at regular intervals.
I believe mine is making the same noise you are describing. I've honestly not put any effort if locating the sound but have always associated the described noise as differential gear wine personally. I'm going to change by diff oil this weekend if time permits. Maybe it will go away but I doubt it. Probably will when I regear eventually. :)
For reference 1997 with 83K.
