Wow, this is great intel. Appreciate you adding this diagnosis to the hive mind!
Sorry for the slow response, was out of town a few days. The part that I used was Beck/Arney 2011788 from Rock Auto, however I wouldn't recommend it because it failed within a few months of installing after I replaced my failed original one (different type of failure, was always open circuit).... Currently seeking other brands.@geoffunkel Great deep dive! What was the part number for the Lo Switch? Issue hasn't popped up since I swapped ECU, but that doesn't mean it won't. At this point, I'm happy to put in a Lo switch for added peace of mind.
I also replaced those switches with beck arnley ones last year. I just yesterday went on partsorq and found the OEM parts and purchased factory ones from Toyotopartsdeal
Finally got around to replacing my low range switch last weekend. I electrically tested the new one before installing and it checked out good. I was messing around with the old Beck/Arney one with an ohm meter and it is for sure bad. Nothing jammed in there. When depressed it closes the circuit as designed and reads around 1 ohm. But sometimes it doesn't go full open circuit when the plunger is released. It reads anywhere from 5-200 ohms, sometimes open circuit; it's all over the place. Clearly something wrong internally in the switch, maybe ATF got into the internal electrical connections somehow. Guess I just got unlucky and got a defective one. The one for my CDL has been working fine for the last couple years.I used the Beck/Arney switch for about the last 80k miles and still going strong. You might try removing and cleaning it, maybe something got in there to jam it. They are very simple switches.
