SOLVED: Looking for size of clutch hose copper washer
Atlanta, GA
In my haste over the weekend, I lost mine with a new slave install. I searched, but could not find any info on the size for this crush washer. I can guess at it, but didnt want to experience any possible leaks with a washer that may be slightly too big. Or does it really matter here?
images
You can buy copper washers for this application at your local a/p stores. They're pretty generic. Similar to something like a 3/8 washer. Maybe take your hose with you.
Thats the idea...but just wanted to confirm with someone here as I am in a pinch.
It looks like the last copper washers i bought was an assortment pack.
Closing this one out for prosperity - in case anyone is searching as well.
Copper crush washer for clutch slave line (line that attached to the slave end - in my case, 1981 US Spec)
Outer Diameter (OD): 14mm
Inner Diameter (ID): 10mm
Besides annealing you can rub them on a flat sharpening stone to remove burrs/high spots. Everything helps to get a good seal.
