I have the king 2.5 lift kit installed on my LC with the Baja Kits UCA and recently I have been experiencing a loud knocking noise coming from the driver side UCA when the suspension compresses in certain scenarios. For example when I'm going relatively fast on large bumps or I when attempting to jump and catch air on dirt roads (nothing crazy, tires barely leaving the ground). The knocking also happens when i go over a pothole and only comes from the front passenger side. I can actually feel the knocking on my feet through the floor of the car.
I checked the issue at 4 different garage shops, none of them were able to find what's causing the clunking/knocking. The bolts connecting the UCA have been checked and have been tightened properly. One of the technicians believes the problem is in the UCA ball joint itself which has worn down, however the UCA itself is not even a year old so I'm not sure if that is possible. I even had to the tires rebalanced and realigned with no success.
Any of you with similar setups experience anything like this?
