Solid pinion spacer?
Fairfax, VA
Getting ready to go to 529's this weekend, any one know if there is a solid pinion spacer available yet for semi-float 80 series rear end. I know its available for the front. Not sure about the rear.
Thanks
Can someone explain to me exactly what the point of the solid spacer is?
Landtank, thanks, good info. Looks like Im go the regular route, probly order a couple crush collars to be safe.
Thanks
:cheers:
Thanks
:cheers:
there are other sources for solid spacers and maybe those would work better. I personally like how easy the install went once they were the right length.
The solid spacers replace the crush sleves which can crush when you dont want them to and thus allow unwanted pinion movement.
