For Sale SOLD!!! NC: 3x Locked 1998 Toyota LandCruiser 100 Series 340k/1000k Miles
The time has come to make room for my next project, which means I'll be parting with this awesome southern truck
I built this 100 series to climb the most challenging trails that Uwharrie and other trails have to offer. This 100 series is a Triple (3x) locked trail and rock crawl ready rig. She has the legendary and strong 2UZ-FE V8 engine with folks documented as surpassing 1,000,000 miles with proper maintenance (google “tundra million miles”); She’s 340k.
The Good: Everything - she’s a smooth and complete trail-ready ride with all the kinks worked out which I daily drive and regularly offroad. She’s been registered and spent most of her life in the Carolinas (North and South Carolina). Previous ownerships have been all within the last extended family. She has super comfortable seats that I’l miss.
The Bad?: The rear drivers window needs a new or refurbished motor if desired. The leather overall is 20 years worn but pretty decent considering the use it’s got - the drivers seat is the worst off and it’s only slightly ripped a bit - I just threw $20 seat covers over the front seats and she looks great. The hood and roof have some sun damage from her days in South Carolina, There are plenty of tree/brush trail marks and dings down the sides as would be expected for something that’s actually taken off road; I call that character
Triple (3x) Locked:
Factory Electric Rear Locker
Factory Locking Transfer Case (4L)
ARB front locking diff (installed by East Coast Gear Supply)
Slee 2nd battery mount and ARB compressor
Armor:
Slee rear bumper with swingout
Slee Step Sliders
Arb Combo Front Bumper
Suspension:
Slee/OME 60000 (front) SOFT
Slee/OME 60002 (back) SOFT
Spring: SOF2RH Slee SOFT
303001 TORSION BAR
SPC upper control arms
Slee diff drop
BFG KM3’s 285/75R16 (33’s)
Other
Smittybilt 12k wireless winch
Weathertech Floor Liners
Nilight Bumper Mounted Spotlights -NI25E-185WLed 9"185w 17000LM
LED interior Lighting
HID Headlight Conversion Kit
Recent Alternator Upgrade
New Fuel Pump
Axels both sides.
Bearings in both front and rear diffs replaced.
Replaced inner and outer tie-rods both sides
Rebuilt drive shafts / u-joints
All major fluids replaced with baseline / action plan
TrekBoxx Expedition Systems Tailgate Cover in Black Richlite with Padded cover
Regularly used Sunroof
Factory comfortable adjustable heated front seats, spacious interior, strong Heat + AC
3rd row seats
If you have any questions - please leave a comment or PM me. Thanks! @FrackMacker
1998 Land Cruiser Maintenance Records:
Note: I have a stack of the previous owners and my current records for major work done.
Previous Owner Notes:
General:
  • Oil always changed every 5,000 miles, conventional
  • Tires rotated every 5,000 miles, now every 3,000-4,000 with mud tires
2-8-05 - Timing belt and water pump (144k)
1-13-06 - Rear brake pads, flush power steering, Re-boot CV axles (163k)
2-2-07 - Front brake pads, re-boot CV axles (warranty) (178k)
11-15-07 - Rear brake pads, spark plugs, 2 coil packs
2-16-08 – Replace trailer light harness, service transmission (199k)
5-21-08 – adjust emergency brake, lube drive shafts (205k)
7-9-08 – new battery (207k)
2-16-09 - install BFG A/Ts , stock size (215k)
2-19-09 – Replace power steering pump (215k)
5-7-09 – Service transfer case and differentials, replace o2 sensor (217K)
8-9-09 – Rear brake pads (221k)
8-14-09 – alignment (221k)
10-22-09 – replace CV axles, front brake pads, replace front passenger side caliper (223k)
1-27-10 – replace starter (lifetime warranty) (?)
2-18-10 – replace lower ball joints, alignment (?)
7-8-10 – replace upper ball joints, alignment (?)
11-12-10 – replace shocks (Bilstein), bleed brakes, lube steering (?)
2-24-12 – replace rear brake rotors, calipers, and pads, re-pack wheel bearings (rear), re –charge AC (245k)
12-19-12 – replace tail light bulb (253k)
3-9-13 – replace radiator (lifetime warranty), replace manifold gasket, front brake pads, replace front driver side caliper, clean injectors, clean intake and MAF (254k)
12-11-13 – replace ignition housing (259k)
1-2-14 – rear brake pads (260k)
2-6-15 - install 285/75/16 Firestone Destination M/Ts (269k)
3-29-16 – replace timing belt and water pump, pulleys, fan clutch, serpentine belt (281k)
7-20-17 – replace front brake rotors, front pads, re-pack front wheel bearings (296k)
Current Ownership Maintenance and Upgrade Timeline:
I’m sure there’s a ton I’ve left out here but here are the highlights I documented.
General
  • 5 Tire rotation and conventional oil change every 1,500-3000 miles
  • Transmission ‘drain and fill’ with every other oil change 7 times.
October 2017
Replaced Hood Struts
Replaced Back Gate Struts
Replaced windshield wipers
LED Lighting replacement for most interior and exterior bulbs
November 2017
Replaced rear parking brake shoes / E-Brake tightened
Brake Fluid Exchange
replaced heater T’s and all front hoses
December 2017
Replaced front Axels
January 2018
new ARB front locking diff and associated compressor via East Coast Gear Supply
slee 2nd battery mount
Lots More! see receipt image for January
February 2018
Gear fluid change: transfer case, rear + front diffs
front brake pads, front wheel bearings, bearing races, rotors, and pads with new pad shims
March 2018
2.5 heavy OME from Slee
slee torsion bars 303001
slee diff drop
slee struts - sport shock LC 100 stiff 60001 and 60003
3” Heavy coil spring rear OME
Lots More! see receipt image for March
April 2018
slee step siders
May/June 2018
ARB Combo front bar
Alternator from napa lifetime warranty
July 2018
Fuel pump
rebuild drive shafts / u-joints
August / Sept 2018
Suspension Change to Soft
New springs: Grey - SOF2RH Slee
October 2018
SCS wheels
BFG KM3’s 285/75R16
  • Like
Reactions: AJR
Photos
Hey what city are you in? How can I get in touch with you on the phone? Thanks
I’ll add that I’d consider a similar value trade on a triple locked 80 series that’s fully armored, 6+ lifted, thats street legal and ready to rumble for rock crawling.. (think front side of Daniel trail @ Uwharrie) and without “major” issues. Prefer something thats reliable and daily driven. 37/38.5’s FTW. I dont care about scratches, that may add to the appeal. I’d also consider 80 series parts / armor in a trade/cash deal - hit me up
@FrackMacker did you buy an 80? I got one that you may interested. Does the front side of Daniel with ease!
