Dan...I have a brand new one that came with our shower enclosure that you can have...no charge. In fact I think I still have the first one I bought...and tried to use it once or twice...you can also have that one!
Didn't work out?
We either are under tree canopy; moving from site to site (not enough time to get the water hot enough); camping in spring or fall when the sun angle isn't the best for maximum efficiency; I put the Helton heat exchanger on the 100 and we don't need it (this puts out some serious hot water now!).
So the plan is I get the solar bag from you. When it dosen't work out you mention the Helton to Mrs. Rusty. If it's not my idea she will probably go for it.
This could work.![]()
I'm not cheap but I can be had. Price? One good draft IPA...Silver Peak, GB or maybe even the new franchise spot at the mall.
Better yet...if we ever get to do an overnighter together she can test the whole set-up out...that'll usually do the trick on convincing!
Believe it or not you can do this with the Camelback water hydration system, Used em in Iraq.
Currently funding for further Cruiser mods has been cut off.Onboard shower is goin in Bob..
those work okay.
But can kill you in the summer out at blackrock...
But I think I have it worked out with spressomon so the OB shower thing will happen eventually. It just needs to be her idea.They can be nasty. The ones on Barney Reily are a lot nicer, rock and mortar tubs with a drain. The convention is you drain the tubs when you leave so they are ready for the next person.I have always wanted a shower after a dip in double hott Yuck lol
