I reinstalled my solar panels and my Victron controller and finally got it all back up and running with thanks to @sdnative . Previously I had a dual battery setup up front, but have since moved to a single battery on the PS side of the vehicle.
The DRL's work through a little controller that turns them on when it senses a battery charge, ie. the vehicle is on and the alternator is charging. Works great.
But, as you guessed, with the solar MPPT controller charging the start battery, the controller for the DRL's sees that it is charging the battery and turns the DRL's on. It actually sequences on, off, on, off, etc. as that is the way the solar charger controller charges the battery.
I may be putting my 2nd battery in the back, but that's a whole different set of problems, though it would resolve this issue.
I am wondering how to prevent the DRL's from coming on while I am charging the start battery. Short of having a switch up front to turn on/off the DRL's positive wire, I don't see a way to do it. Though I am sure someone else has encountered this issue and resolved it without a switch.
