Soft top hard doors.
Yes you can. If you look in my ROTW thread, you will see the soft top with both.
That's the way I run mine!!!!!!!!!!!
i hope so...i've been doing it for decades :D
mine is a factory soft top and it has hard doors. dont know if the doors are stock but they work. i wish i had some pics
well that explains why they dont shut worth a s***. thanks
they should shut just fine. they're setup the same as the oem soft doors except for the actual latching. if the tops an aftermarket top, you may find that there area gaps in the upper rear corner, but that's the top manufacturer, not the doors.
That's the national setup of blues lovin hippies from colorado. Had a blues traveler concert in Angel Fire, NM a few years back...must've seen a dozen or more set up like that.
my top is factory. the only problem i have is that passerger doors doesnt latch too well. i tried to shim it and adjust everything but i guess it just doesnt want to go. oh well. that means i ahve 2 more things to add to my list of unstock peices on my cruiser
