There was never any issue with my Bestop either. The Julie’s Dirt Road top is slightly different at the upper front corners. I should probably have noted that.If your concerned about scratching the paint wound just out some.high quality electric tape on the channel. Use an awl for the seven holes for the bolts. Could do the same for the edge of the channel. Never had an issue with factory channel with my Kayline tops.
