Thanks Matt. I could always text John (LITP) but I know that Whitey's opinion is pretty solid since he has these same doors. Thanks for the Avatar kudos--yep, it does fit. Kind of a Tranformerish looking.
I think that is correct as I recall per a post Mark did in another thread. Can't wait to get my knobs--I should have the choke and vent knobs off to you in a couple of weeks--you are still up at 3 a.m. in Maryland I see--nice --typical Matt![]()
I think the shorter ones are for the FST so the doors don't open far enough to fall out of the hinges. I had to find a pair for my build, not sure which I got, and in my case either will work as I'm using QuikHinges rather than factory.
You could be right. My experience with the factory FST hinges is limited, as my rig did not come with a full set. That's why I changed to @69LC 's Quik Hinges. Those are strong enough to use with hard doors as well. Switching between soft and hard would not require changing the hinges on the tub.Thought it was the other way around. You don't have to worry about the soft doors falling off. They have to lift up and out of the factory soft top hinges. Being the top of the hinge is only half a circle worry more of the weight of hard doors on them. When I switch between hard and soft doors I switch hinges at the same time.
When I had them mounted, they were mounted correctly. Of course, since the tub is bare now...How do you have your hinges mounted?
Do you have them so the doors drop in and lift off?
