- Location
- United States
Two hubs, full set of bolts, and 4 hub gaskets. $150 plus the ride.
Will do.@65swb45 Mark add it to my pile please.
Just waiting on the last few $$ for shipping.@65swb45
Amazing Mark! I’ll take everything except the Phillips head jack. However depending on info maybe it as well.
Slotted screws are the earlier of the 2 jacks you have. This slotted screw jack dates to 1965-1969 FJ-40/45/55. There should be a 2 character date code on the rim at the top of the neck flange. This will give you month/year.
What does it say above the model number on the Phillips head screw jack? I zoomed in but it just gets blurry. TEQ or TOYOTA MOTORS?
There should be a 2 character date code on the rim at the top of the neck flange. This will give you month/year. What is it?
TEQ dates it at ‘70-‘71. TOYOTA MOTORS dates it at ‘72-‘76 if it’s neck flange is the same size as the slotted screw jack. If it’s a wider neck flange then it dates ‘77-‘78. Hopefully this info will help you sell it if I don’t purchase it.
Any chance the crank handle has a “STO” on it? Or do you have one that does have the STO on it? STO handles are ‘69 and older.
I’m looking to also purchase any of the jacks in the first 2 pics. Easiest way to identify them is the slotted neck screw is opposite the crank handle.
