soa is finally done
yeah they are both anit inversion the ones up front are two inches longer(RSK) and i got them from man-a-fre and the ones in the back are 1 1/2 longer and i got them from jto. i dont remember the ones from jto were called but the ones up front are made wayyyy better heavy duty...im loving the spring over more and more every min.. haha everyone at work wanted a ride :)
well im out
-al
oh yeah its my pinion angle..how bad can you mess things up til my shims get here? ill just be drivin it around town for like a week til they get here.. will i hurt anything?
thanks agian -al
Nope, you'll just wear your u-joints, and various bearings faster. Depending on how much vibration I wouldn't drive on the freeway.
That said, I drove two 300 mile trips on a horribly failing rear u-joint. Not much fun. :doh:
When you get the angle under control, check for slop in the d-shafts.:D
I would definitley get the knuckles turned. That caster degree designed in in the front axle is pretty important. But hell if you don't mind then rock on. :D It seems to me the caster being incorrect would cause vibration? :-\
it only vibrates when its in gear or under gas so im almost positive its my pinion angle, plus just by looking at the back axle you can tell its rocked up a lil :( owell its the first time i didi this so i guess ya cant count on it being perfect but ill slap some shims on as soon as i can.....
rock on...
-al
[quote author=UGLY88 link=board=1;threadid=8706;start=msg74979#msg74979 date=1071254346]
With out the proper caster the truck is no longer keeping the wheels straight for you as you drive. Because of this you are no longer fighting the correct geometry of the steering system. The down side is that it is easier for the imperfetions in the road(such as ruts and such) to steer the wheels for you as well. If I am off base with this, let me know you guys.
[/quote]
yup thats correct ... you caster is close to zero now so the steering will "float" this will make it raod walkk more at highway speeds but you get used to it :cheers:... looks bad ass can't wait to do that to mine :-\
