So......it has been diagnosed!
Tucson, Az.
After about 3 weeks of a sudden vibration coming on, the 80 has been diagnosed with 2 tires out of round. Much to my disbelief as I thought it was bad u-joints (replaced them anyway) and this did not do a thing. The truck is lifted and on 35" MTR's, is this happening to a lot of guys? Any recourse through the manufacturer? They now have around 20k miles and like I said this was overnight change!
Thanks!
Happened to me several times; in my current truck and another I had. Now mine where not only out of round, they had bulges, most of the time caused by hitting a pothole, and we have those here dime a dozen. Do you have road hazard warranty on those tires?:cheers:
x2 on the weights. I did this on 2 tires with my Pathfinder a few years ago
I actually started there and had it balanced right away. They said one was off the rest were good. Vibration continued, replaced u-joints, still there. They put it up on the balance machine and could see that 2 tires indeed had a flat spot. No hard braking, no major potholes.:confused:
They could have balanced then you knocked the weights off, happens all the time
or are you saying something happened to the tires themselves?
Did you lock up your brakes while on the freeway or something and make big flat spots on them just prior to the problem?
Yes, 3 different mechanics and a buddy with the same truck and tires. What can you say when you can see the flat spot when the tires are spinning on the machine?
What gets me is how this came on all of a sudden.
Thanks for the feedback.
anybody else drive your truck?
