Throw that sucker in the garbage....they are nothing but trouble.....however how can you sell that rig to doc?
Excellent post! There is a lot about my 62 that I am not aware of and this forum is a daily learning experience! I have hauled some heavy loads of wood and wondered if there was some mechanism to compensate for the load since I didn't need to press the brakes any harder than normal. Now I know...
...and the 62 continues to prove its supremecy over the 60.![]()
Throw that sucker in the garbage....they are nothing but trouble.....however how can you sell that rig to doc?![]()
LMAO you are kidding right!
its a load sensing proportion valve.... More weight in rear=more brake pressure in the rear
Two pages of posts, and no one tells the guy it's possible to change the shocks from beneath the truck?
All of this is true and correct.This is sort of right. It's really a lack-of-load sensing proportioning valve. In a sudden stop situation, the weight of the vehicle shifts to the front an the back lifts. The lspv detects that and decreases pressure to the rear brakes to avoid rear wheel lockup and loss of traction. When you put a lift on your vehicle, the lspv goes out of adjustment and decreases pressure under normal conditions. You need to put a spacer on lifted vehicles to maintain the proper distance between the tub and the rear axle. When you do that your brakes won't be mushy anymore.
Bill
Somewhere else that sees regular ice on the roads *might* justify adding this item, but it is not ABS and I doubt the utility of the considerable work need for the install (note that there is a front brake system tube run all the way back to it) without a demostrated need for such a device.
Just trying to clarify the purpose of a seemingly somewhat misunderstood safety device.
Bill
The reason I asked my questions is because I did not know what it was.
