- Thread starter
- #21
Install of the ebay snorkel is finished!!
Overall this product is very solid and well built. The ONLY thing that bothers me is that the top part of the snorkel had a different finish the main body and that they send you 3 pop rivets rather than screws or bolts to mount the bracket on the pillar beside the windshield, I pre-drilled holes and used screws. This is just me being VERY picky. The only time consuming part was moving the intake to the opposite side of the air filter housing. Here are the pics
Careful cutting!
Don't rip the cardboard!! You will have to open the holes in the fender.
DO NOT attempt this without a hole saw!!! I used one that was .250" smaller than needed, use a 3.250" or ideally larger. Only drill the 2 forward most mounting holes, the third would be pretty hard to get the nut on.
Once you get the holes in, slide the snorkel in and mark the bracket location on the pillar. Then take the bracket off, mark and drill the holes ect. ect.
Once you get to the point where you are ready to install the intake hose from the snorkel to the breather use the round hole behind the battery not the square like I started to do, I actually cut the square hole bigger to fit the hose before I saw the one behind the battery.
Hook it to the breather and your done.
Yes, it is that easy.
Also while your welding and cutting seal up the air filter housing.
Careful cutting!
