Your engine will fill up with old oil residue.@WildernessRimFab … makes sense, thx
So what are the ramifications of plugging both ends?
Thanks Nolan, I see what that means on the engine side - what about blocking that end of the riser under the Sniper? Just for my own education, what are the consequences of doing that?
I’ll take your advice and put the new pcv on top of the threaded (and hollow) old pcv
My O2 sensor that came with the sniper lasted only 8 months! That's what made me decide. The heat sink bung supposedly extends the life of the sensor.What made you decide to put the heat sink bung extender on?
I didnt turn on the igniton repeatedly without starting but this is something good to think about for the future.Any chance you have turned the key on a bunch of times without starting it? I’ve seen people that were doing wiring turn to switched 12 multiple times and it kept priming and sent a lot of raw gas down when they finally start the truck fouling the O2
Had you messed with the prime or was it stock?I remembered that I bought the Bosch 02 sensor at O'Reilly's, so they happily exchanged it within the 1 yr warranty period.
Installed new sensor, reduced fuel prime to 60 percent (was at 100%), reduced fuel prime multiplier to 3 (was 5). Started right up and ran perfectly.
I'll report back when this sensor grenades, and keep reducing the fuel prime parameters until I have starting issues.
I would imagine that the default settings on the Sniper are based on easy starts and not 02 sensor longevity?
I had a saved version of the baseline setup map, 100% fuel prime and 5 fuel prime multipler was indeed stock. I did not mess with that previously.Had you messed with the prime or was it stock?
