Small play in front driver side tire
Wake Forest, NC
Hi All -
I have a 2003 GX 470 with about 150K on it (we got it with 80K on it). It is a daily driver for the wife and kids. I had it up on jacks and noticed the ever so slightest play in the driver side tire (both up and down and side to side). In fact, I would have thought nothing of it except for the passenger side has absolutely no play.
I thought it might be the ball joints. After all, it has 150K on it and I think the joints are original.
Replaced the ball joints and still have the same play. I thought it might be a debris on the rim and rotor, cleaned the mating surfaces. Still there. Thought it might be a warped rim, so I changed wheels. Still there.
Any thoughts as to what might be happening?
Thanks for any advice
Thanks @Jstawgn
Pulled the hub and wheeling bearing today. Driver side was definitely bad.
FYI to any future readers - I purchased the Koyo bearing with hub preassembled on ebay.
Item got here fast and changing out was relatively simple.
FYI, if the DS is bad, the PS might not be far behind :). Both of mine were smoked at 170K and the bearings I took out were non-OEM Chinese bearings. I had bought the rig at 135K so the OEM bearings must have failed sometime prior to that. This time I also used pre-assembled Koyo bearings/Doorman hubs, but got them from yotabearingsandhubs.com.
At least it's an amazingly simple/easy job on the 120 platform. We did the bearings on my buddy's 1st gen Tundra, which required pulling the steering knuckle completely out of the rig and using a shop press to remove the bearing. Toyota seemed to learn their lesson from the older 3rd gen 4Runner-style suspension/front drivetrain and made a ton of improvements to the ball joints, wheel bearings, and CVs for our platform.
Oh ya, I changed out both sides
