By using VIN at PQ, you see your vehicle, even its colors and build date. Build date, key to correct parts.
Both ATF. Red circle is ATF oil cooler hose from transmission (A/T), goes into bottom of rad. Blue is its "OUT"ATF oil cooler hose, from rad to oil cooler (small radiator in front on AC condensor and radiator).
Here's the pre oil cool, that is in bottom of radiator. Nipple thread on it that, hoses connect to. Interesting, in 200 series follow is reversed.
This clear hose attached to ATF return nipple (Red arrow points to) from oil cooler radiator. Runs to a catch bucket for A/T flushing. This happens to be 98-02, which ATF lines are the same, but power steering hoses (blue arrow) are a bit different configuration, than 03-07.
The OUT bottom of rad ATF cooler hose, Is just out of sight, below return nipple (red). It goes (in) to ATF oil cooler radiator in front of AC condensor.
ATF oil cooler (yellow arrow) radiator
When we say "oil cooler". Many think of engine oil cooler. Engine oil cooler, is only the parts oil filter attaches to. It has coolant hose from block, then out to pipe going up front of engine. Oil filter nor hose is attached in this picture
