Small cracks in transfer case - is it structurally compromised?
SW MB CA
This is a 3-speed t-case mated to an SM420. The other day I noticed a couple small cracks in the case under the low range output gear that appear to be minimally seaping oil. Presumably this happened a few years ago when the hardware holding the input gear on the 420 output shaft got loose and went for a ride.
Am I right in thinking the cracks are of little/no structural significance based on where they are? Will they spread? Clean it up good and epoxy over it to seal? The case has a @orangefj45 t-case saver and nose cone ring, and with a quick look over I don't see any other issues on the exterior. The thin/worn spot the crack runs into is from before I had the case (rubbed against a skidplate?).
If you have oil seeping thru any cracks I would be concerned. Personally I would replace the case, but I also spare cases. The SM420 has a first gear lower than the three has. About double. Larger tires and lockers would a lot more torque then what the vehicle had originally.
Based on the look of the bolt in your hand as well as the metal chips I'd say something exploded inside the case so yes it is compromised.
Not the usual place and direction in which they crack but if it is leaking you got a serious problem. Years ago I had one crack in the usual place and had it tig welded before it got worse and it held just fine.
