This is probably a dumb question, but is the input bearing on a SM420 pressed into the housing? I know it's pressed onto the input shaft, but I can't seem to get it to come out of the housing. I wanted to make sure I wasn't supposed to be using a puller before I start beating on it. If it makes a difference, this is an early one with the threaded oil slinger input shaft.
Also, are the early and later input shafts interchangeable? If I have a junk later trans with the seal on the input shaft, can I swap it onto my earlier transmission? If not, I guess I'll send this one to Novak to get the seal conversion done.
