Sluggish windows fixed for $40!!!! Dial-up grab a coffee
Discussion in '60-Series Wagons' started by doctorjj, Mar 4, 2007.
  1. doctorjj
    doctorjj
    188
    1
    Feb 21, 2007
    Well, this is my first post on Mud, so here goes.
    I've been having the slow up and down on my windows for a while now. I had tried a lot of different things, greasing the mechanism, cleaning and silicone to the rubber, etc. Nothing seemed to work. So I decided to just go ahead and totally replace the window rubber. I ordered new weatherstripping from JC Whitney. I ordered 4 lengths of the Style 27. That is enough to do all four windows all the way around. It was just over $40 with shipping.
    http://www.jcwhitney.com/autoparts/...Id-100000220223/Pr-p_CATENTRY_ID:100000220223
    This is how I did it.
    First here's a look at the windows before I started. Old junky rubber. Shrunk down with some gaps. Very hard and brittle
    [​IMG]
    And here's a link to a vid of the window going down then up. VERY SLOWLY!!!!
    http://video.google.com/videoplay?docid=-4137309917564881508
    Now here are some pics of me replacing the rubber.
    First is the bezel around the door handle.
    [​IMG]
    Next is the grab handle.
    [​IMG]
    Here's a quick vid of me getting the clips to come loose.
    http://video.google.com/videoplay?docid=-1908245471888385560
    And then you take off the door panel. Just lift up a bit ot get it up over the lip. Then you can sit it on the ground. You don't have to undo the wiring, but if you want to, there is a quick connect.
    http://video.google.com/videoplay?docid=-4847782143138000165
    Then the bolt that holds in the front slide.
    [​IMG]
    Once the bolt is out. You can remove the front slide. Here's a quick vid of that. Once the bolt is out, just slide it down out of the groove and it's then loose.
    http://video.google.com/videoplay?docid=-93243533233422177
    Then out with the old rubber.
    [​IMG]
    And now in with the new
    [​IMG]
    Here's another vid of me starting to put the rubber in the front slide. No reason to take the slide all the way out. Just pull it out to where the clip is at the top of the door. You can put the rubber in from there.
    http://video.google.com/videoplay?docid=2988063719186285218
    Once you have the rubber in, just reinstall everything. Just make sure the glass is seated in the slide both front and back. Also, don't forget to grease the rollers while you're there.
    Here are a few pics of the windows inside and out after the install.
    [​IMG]
    [​IMG]
    And a final video showing the window going up and down.
    http://video.google.com/videoplay?docid=7549677071202585689
    Still might seem a bit sluggish if you just watch this final video, but it is already almost twice as fast!!!! First video takes almost 30 seconds to go down then up. This one is right around 16 seconds. I think it will speed up a little more in a few days as the rubber gets seated better and gets a little memory to it with the glass in. All in all, it took me a little over an hour to do the front two windows.
  2. ballardcruiser
    ballardcruiser
    345
    Media:
    3
    22
    Jan 9, 2005
    Seattle
    Great first post! I need to do this... So no adhesive/silicone is needed to get the rubber to stick to the door groove?
  3. doctorjj
    doctorjj
    188
    1
    Feb 21, 2007
    Thanks.
    No, the rubber has little wings on it that grab. Here's a pic.
    [​IMG]
  4. klinetime574
    klinetime574 Positive Vibes SILVER Star
    5,372
    591
    Jul 23, 2006
    Chicago, IL
    Great job. Very in-depth.
    Welcome to Mud :flipoff2: <---Official Mud Greeting
  5. doctorjj
    doctorjj
    188
    1
    Feb 21, 2007
    Oh yeah? Well, :flipoff2: all ya'll then!!!!!!!
  6. Nightshadow
    Nightshadow
    89
    Sep 25, 2005
    Grants Pass, OR
    Nice job! :)
  7. cando john
    cando john
    134
    Sep 14, 2006
    philadelphia
    way cool .....nice job
  8. doctorjj
    doctorjj
    188
    1
    Feb 21, 2007
    Thanks for the compliments.
  9. azaussie
    azaussie
    459
    Feb 14, 2005
    "Dial-up grab a coffee." Well, I would like to watch the videos as I need to try this on the front passenger side - good reason for me to get high-speed.
  10. agent orange
    agent orange
    2,227
    8
    Jul 8, 2005
    New Kent, VA
    Haha, i just watched the videos, you think yours were bad? Mine move like icebergs. Great writeup, the videos are a nice touch. Did you put any silicon on the weatherstripping? It might cut down on the squealing in the last video.
  11. doctorjj
    doctorjj
    188
    1
    Feb 21, 2007
    No silicon on the new weatherstripping. As for the noise, I tried to find it as I was reassembling and as best I could tell, it was coming from the motor itself or the gears. I couldn't get it to be gone completely. I guess they aren't used to moving that fast. ;p
    If it doesn't go away, I'll go back in there and look a little harder. The passenger side front is the only one that does it.
  12. mkaustin
    mkaustin
    329
    Media:
    1
    10
    May 14, 2004
    The Great State of Texas
    Looks good.
    So how did you handle the top corner? Did you have to cut the new strip to bend the 90 degree coner??
  13. Skniper
    Skniper
    1,171
    524
    Sep 29, 2004
    Houston, the bowel of TX
    I think the same window strips are available OEM for relatively cheap.
  14. doctorjj
    doctorjj
    188
    1
    Feb 21, 2007
    At the top corner, I simply cut the weather stripping. I bent it at first, but it didn't look good. Cut looks great and seals it up just fine.
    "I think the same window strips are available OEM for relatively cheap"
    How cheap? $40 for all 4 windows?????
  15. Spook50
    Spook50 Get ready
    5,024
    990
    Feb 16, 2005
    Spokane, WA
    VERY good for a first post! I thought my windows were bad when they took about 15 seconds one way and still seemed sluggish when I redid all the switches and lubed everything, which got 'em down to about 8 seconds one way. I've still got all the original factory rubber tracks, so I'm gonna have to try this stuff and see if that makes more of a difference with my windows.
    and welcome to Mud :flipoff2:
  16. lonelydriver
    lonelydriver
    442
    3
    Nov 20, 2005
    Pasadena, CA
    Well I ordered these rubber tracks, and I spent about 3 frustrating hours trying to get everything back in and in the end gave up. These tracks are not the exact same as the oem ones. the "hooks" that hold the track into the window channel extend higher on these and therefore dont fit into the original space and end up pinching more then they should. as a result there is no room for the window glass in b/w. i'm not sure if they changed the style or something but the ones mentioned in the first post don't work.
    No offense to Doctorjj, they must have changed the channels, because his seem to work great.
    Hope this saves someone some money and trouble :(
    ended up just removing and cleaning the old ones with silicon, and they are much faster.
    should have gone with oem!
  17. Gappy
    Gappy
    3,249
    111
    May 24, 2005
    NE Indiana
    Nice job on a very well put together post DocJJ!!! After watching your first video, my windows don't seem so slow any more.
    If I may make one suggestion, you could do better than Kenny Chesney on the install music on the second video.;)
  18. Tinker
    Tinker
    2,865
    9
    Apr 15, 2004
    Larkspur, CO
    Having been in the auto glass biz for longer than lots of the folks on this forum have driven legally, I recommend using OEM whenever available. When that's not possible, you're in for an adventure with aftermarket stuff.
    Good work, however. Most glass shops should have access to that same molding through the CR.Laurence company.
  19. Tvaldriz
    Tvaldriz
    449
    1
    Dec 23, 2007
    SF Bay area, California
    Great post!
    Really nice post! Videos were a big help, as well as the still pics
    and diagram.
    Great contribution to the effort to keep these rigs rolling and the
    windows going up and down!
    Tom
  20. bowhunter
    bowhunter
    1
    May 17, 2008
    OEM Prices
    Wow!! :eek: :eek: Oem might be the way to go but you better bring your pay check..
    Fronts are 79.24 ea
    Rears are 104.78 ea
    That 368.04 plus tax :crybaby:
