Slow and squeaky driver's side window
Eugene, OR
I searched for threads or FAQs on this and came up dry. I'm assuming lubrication would be a good starting point. Any recommendations, or pitfalls to look out for in trying to address this? 1999 TLC. I think the motor is just tired, and tracks are getting dry.
Thanks, Spank
Thanks. Any tricks to the door panel removal? Just pop off like other panels in the 100?
I would try cleaning and lubricating without removing the door panel and see if it improves. Get some silicon spray and shoot it in the window tracks with the window down. Roll up and down and repeat.
Door panel is no big deal, probably in the FAQ. There are clips or screws on the bottom of the door (under the sill), one near the handle, pop off the courtesy light and the master switches and unplug harnesses (think the spring side is towards the rear of the panel), some clips near the rear vertical of the panel, and pop off the tweeter grill. It should lift off vertically or pull off horizontally after that.
Having the same issue, only thing that helped was taking apart the motor. Unfortunately mine has some "chunks" missing from the plastic rod and is due for replacement.
Reset it per the FSM before you have bigger problems, ask me how I know.:rolleyes:
Eventually the tab mounts on the window will break if you don't attend to this.
Hi guys, while you are on the subject. I have a 2000 LC with 155K miles, the rear windows are very slow going up. I was told to look for replacement motors. Any thoughts or advice on where to shop for motors??
Just to add to the above cleaning, use Q tips for the window channels with some alcohol (just plain rubbing alcohol) and clean the channels real good then add a dry lubricant, something that you can by at a bicycle shop that is used on bicycle chains. This will help not getting smudges on your windows from the silicone.
Since you say both windows are slow I'd check your system voltage first, low fruit easy to do. My windows were noticeably faster after I put a new battery in a few months ago.
The motors do not run slower due to age, But maybe you need to “lubricate” the rubber trace that the windows run in. The rubber gets old and won’t be as smooth anymore. You should be able to hear if the motor is working hard to get the windows up/down. I used dry silicone that I sprayed into the rubber trace, that really did the trick for me, they now run as new, and you don't even have to take the door apart.
Roll down the window and just spray the inside of the rubber track up and down in each side of the window. Roll the window up again, roll down and repeat a second time – it’s not greasy in any way. Before I sprayed I did buy new rubber tracks, but just wanted to test and try with the spray first. It has now been working for more than a year now, and I still have the new rubber track laying in my garage.
I'll have to try that, I always figured it was an internal thing... I can hear that the rears on my truck are trying very hard as well, sometimes the driver window too. If all you did was spray the rubber around the window opening that sounds like a great start.
As a side note, I just replaced my battery as well and the windows are definitely a bit faster.
I'm on it. I'll start with the dry silicone spray in the tracks. Hope that fixes it as I'm lazy/incompetent at most repairs. :)
So last night I sprayed silicon spray into the rubber tracks on all vertical parts of the rubber guides. I didn't want to do too much, but after cycling them a few times I think it's marginally better, but not awesome. I have no reference of how the should be is the issue. I'm not sure at what point it will be as good as it gets... maybe I should do a bit more and really get it in there? How aggressive were you @bjarnep?
With my 2003, I recently had some electrical problems with the front passenger window switch. It would not go up or down like it was supposed to.
Last week I did a speaker upgrade and after putting the door back together, the switch would not work. Turns out the culprit was the window switch computer. It was not plugged in all the way.
After troubleshooting, I was able to push it back in place and, the window worked better than it has in 10 years!
With the window switches, you may or may not need a new one. Check the computer of the switch and, make sure it is plugged in all the way. Your problem could be a bad connection.
I had a slow noisy driver window. I removed the drivers switch to pull off the wood trim to find the connector was not all the way on. I snapped in the white plug and the window now works way better.
Although it still hits the top and rolls 1/2 way back down if you use the auto up :( I have not wanted to pull the pannle and fix that yet lol.
@rusty_tlc Can you point me to where in the FSM that is? After my fix of a broken tab the auto-up no longer works so I think I need to do this.
Make sure it is the ”dry” type, then be generous. I think I used ¼ of the big can on 4 windows.
It is the 2 sides of the U shaped rubber tray that has to be sprayed
Previous owner read online to 'lubricate the tracks' and dumped most of a can into the U-channels... of WET silicone. My window is now always dirty/dusty and unless anyoen has a good suggestion for getting that silicone out, I am looking to replace the seals <sigh> So MAKE SURE YOU BUY THE DRY
@TRDOffroad03 In process of troubleshooting slow passenger windows now, can you point me to the location of this 'computer'? Do you mean the wiring block in the driver door, or something else?
