Slow and squeaky driver's side window
@rusty_tlc Can you point me to where in the FSM that is? After my fix of a broken tab the auto-up no longer works so I think I need to do this.
Previous owner read online to 'lubricate the tracks' and dumped most of a can into the U-channels... of WET silicone. My window is now always dirty/dusty and unless anyoen has a good suggestion for getting that silicone out, I am looking to replace the seals <sigh> So MAKE SURE YOU BUY THE DRY
@TRDOffroad03 In process of troubleshooting slow passenger windows now, can you point me to the location of this 'computer'? Do you mean the wiring block in the driver door, or something else?
By the window switch computer, I mean the window switch assembly. On the right passenger door, there was a wire that plugged into the window switch module. In our case, it was slightly loose and, by pushing the clip in all the way, the window switch worked again at full power. You need to remove the door panel to access the window switch assembly.
Otherwise, you probally will need to get a window switch motor. A new one from Toyota would be expensive but, if worse comes to worse, scurry a junkyard for the part. Hope this info helps:D
I had a slow noisy driver window. I removed the drivers switch to pull off the wood trim to find the connector was not all the way on. I snapped in the white plug and the window now works way better.
Although it still hits the top and rolls 1/2 way back down if you use the auto up :( I have not wanted to pull the pannle and fix that yet lol.
Hi ScubaJon,
Did you have a chance to figure out how to fix the issue with auto-up rolling 1/2 way back down right after hitting the top? My driver side has the same issue when weather is cold.
Thanks!
Hi ScubaJon,
Thanks!
This has been solved search the forums I posted in the thread explaining the procedure when i was replacing the window channel to fix slow window. The issue is the window pinch on the auto roll up needs to be reset.
