- Thread starter
- #21
Just for follow up...
Drivers side:
I folded a strip of galvanized steel to about 6" long & 1/8" thick and drilled a hole in one end big enough for the top of the U-bolt to fit through.
Placed the strip between the slider bracket and the frame, hanging from the top of the u-bolt. It reached about halfway down the side of the frame.
When all was snugged up, the slider rail sat about 3/8" from the pinch weld, PERFECT!
Passenger side:
Put four 1/8" thick washers between the cat guard and the frame then bolted it up. Also, about 3/8" from pinch weld now.
No more banging on pinch weld and no grinding or bending required.
Thank you all for the input.
Drivers side:
Passenger side:
