Cristo,
From your web site:
Machining
This was the most time consuming part of the kit; I had to go to many different machine shops to find someone who could even cut this hardened output shaft. My advice to you is first finding someone in your area that can do this job. The machinist is going to either need a toolpost grinder or high speed lathe, my machinist used a toolpost grinder. I also talked to a toolmaker that could have done the job, but he directed me to someone who could complete the job cheaper. One other note, the plans that were included in the kit were not entirely accurate when comparing dimensions to the actual shaft. According to Rob Kay there are very slight variations in sizes for the output shaft. I also ran into a problem with my carrier bearing. The bearing inside diameter was a couple thousandths larger then the outside diameter of the new center diff carrier provided with the kit. The bearing could move on and off by hand. You can see a picture of the new carrier on (
Figure 6) and you can also see a picture of the new carrier in place on the center diff before the bearing has been pressed on. (
Figure 3) This problem was fixed by machining very small grooves on the mating surface of the center diff carrier and using a thread lock like product. According to Rob Kay this is also the same procedure they had used to fix this problem. He also said getting a new bearing would also work. You can see a picture of the bearing installed on the new center diff carrier and bolted to the center diff. (
Figure 4)
Has this been changed/corrected?
Also, will regular ASCO hubs from a FJ60 work up front?
Thanks...Don
