SLEE Rear Bumper... Adjustable Vertically???
I searched the threads and SLEE's rear bumper install instructions and could not find a clear answer.
I know this may seem to be an odd question to most of you wanting more ground clearance but any help/input would be appreciated.
Is the Slee rear bumper adjustable? I need to drop mine 1/8" to 1/4" at most. There are two shims on the bottom of mine but can more be added to drop the mounting lower?
Looking over the instructions and being familar with the rear of the truck from building my own bumper I would guess that there would be two limiting factors to dropping the bumper 1/8" to 1/4"
1: The attachment points that go to the side of the frame. You might need to oval a couple holes here. Not a big deal.
2: The profile of the bumper itself. It will slide over the end of the frame, boxing it in. You will have your answer if you take out all the mounting bolts so it is resting on the top of the frame. Whatever gap you have between the bottom of the frame and the bottom mounting holes is as low as you can go.
HTH, and good luck!
