Slee extended brake lines
Opelika, AL
I have a 94 landcruiser with rear drums. Which set of brake lines do I need? The ones for the 91-92 (a 2 line set), since my truck has rear drums like these models (OR) the ones for the 93-97 (a 3 line set), since this year range covers my truck's year. I'm talking about the frame to axle kits. I'm only seeing a single line coming down in the front that splits in a kinda W formation and goes to each side. Maybe the other 2 go to the rear if I'm supposed to use the 93-97, I dunno. Help Please.
Best thing you can do is call Christo and he will tell you and you can order right then
I don't mean to under estimate Christo but my truck is that oddball 94 and I thought I'd ask here first to get a little info before calling him.
I'll take your advice though Romer. Thanks.
I didn't call him yet because right after this post I found somebody that would rebuild my knuckles fairly cheap. Think I might have to hold off on the brake lines for 2 more weeks. I haven't installed my lift yet so they can wait. I'll post up the response then though.
After all this time has past I still haven't been able to move forward with the brake lines. I did figure out which brake lines I need without calling Slee though. I just got under there and followed all the brake lines and saw that I need the older model ones. Sometimes I make things more difficult than they have to be.
Todays date: 5-17-08
I did finally order the brake lines from slee last week. I did need the 91/92 type since I have the rear drums. This is posted for the folks that, as someone from slee off road put it, "have one of those unicorns"
