Slave cylinder pushrod lengths
kcisland
snohomish, wa
Working on my Slave cylinder install and looking to see if someone has the specifications/numbers on the different pushrod lengths and part numbers.
So when I disassembled the engine the PO had a socket added to the end of the pushrod to add length.
1924713
1924714
1924715
I thought ordering a new slave/push rod for my year (2/1970) would fix the issue but I was wrong. The pushrod at 4" long is still shy 1 1/2" from the clutch arm, with the clutch arm holding the throw out bearing 1/8" from the clutch fingers.
1924860
1924861
Can anyone help with the proper length and part number for the longer or correct push rod? I saw a picture of one on Coolerman's website showing the longer pushrod...I will put it in the next post.
That is not the correct pushrod configuration Keith. The ballstud on the end should not let the threads protrude like a 4speed.
And they are definitely longer like the pic you have from coolerman. I just added a pic of the early pushrods to the clutch section of my website last week. 070-21A
