slack in drivetrain???
richmond va
:confused: have 94 stock fj. 148000 miles. driving between 40/60 mph upon releacing the gas pedal you feel (hear) a loud bump. reapply gas after coasting same thing. i am second owner. bought it off a preacher who never wheeled it.
i have checked
u joints frount and rear (no slack and greased)
ring gears(jacked truck,disconnected drive shafts,rotated wheels and watched pinoin shaft for play.seems ok to me.)
i feel the problem is in the T-case. i have done two sye kits on np231's and put a gear set in a d300 case. this is the wifes daily driver and ive never worked on a toyota case. plus the thing looks like it should be in a johndeer not a suv.anything else i should check? is it gear or chain driven? also frount and rear yokes feel like in good alignment with no seals leakn. if you hold frount yoke and turn rear there is some play. is that normal? any info would be a great help. also im new to ih8mud and computers if you cant tell. thanks
I had the same thing in my '91...a loud dull bang when I let off the throttle. Most of it went away when I swapped the tranny and t-case when I did my diesel swap...so I very well could have had a lot of slack in my t-case. People here have also suggested that the drive flanges could be worn out...and the tiny bit of slack as the axles load and unload is enough to make that banging sound. I've yet to swap mine. IIRC the banging was less pronounced when I had the central diff lock on.
thanks
thanks for gett'n me in the right place on the boards. still would like input on problem.
any surrestions??
i still believe problem lies in the transfer case. anyone been in one? by its size in looks chain driven? if so is there a gear driven/part time option that would bolt in less a drive shaft changes?? daily driver/beach runner use.
It could be lots of things; basically too much accumulated slop throughout the drive train. Does it clunk when you go back and forth from D to R when the truck is stopped? If so, maybe you could get close enough to hear where the noise is coming from.
only when driving
had it on a friends lift and went thru all gears. park to reverse,reverse to neutral,neutral to drive so on and so forth. many times. only does it between 40/60 mph upon releacing or pressing the throttle. have even tryed feathering gas pedal slowly. still has scary sound and feel.
I'm no expert but maybe try adjusting the tranny kickdown cable under the hood where all the throttle linkage and cruise control crap lives. Here is a search tab up above and you can search for all kinds of useful stuff. :cheers: and welcome. :flipoff2: this is just the official ih8mud welcome!
Try this here and let us know if it worked!
80-series Throttle Adjustment - Land Cruiser Tech from IH8MUD.com
thanks for official welcom and info. will try it out in near future. good to see there are some guys on this site who share the common camp fire humor i love. anyone wheel in or around va like myself? or does it have to be some secret landcruiser event to get you guys in the woods? have yet to see another fj at an event that i go to. are you guys like the landrovers that only wheel together or better yet the CAMP JEEP sticker wearers we have at every traffic light around richmond. just like to see a few more 40's on the trail. :flipoff2:thanks.and back atya!
