The stock exhaust did not run above the skid plate. Aftermarket header pipes were sold that routed the exhaust over the skid plate but not from the factory. The over skid plate exhaust gets tight when running the OEM PTO winch. Too much heat next to the PTO. melted a spot on my PTO case once.
Man-a-fre's bolt on exhaust is a great example of what you're looking for - don't have a pic handy at the moment though. It catches the header right where the frame flattens, kicks in about 2" (towards vehicle center) and runs parallel to frame and kicks up into muffler, which bolts to a frame bracket on the up side of the hump for the rear suspension. From the muffler exit it goes up over the suspension hump, down and exits the driver rear with a bracket right behind the tire. Hope that gives you a mental picture.
BTW - who makes aftermarket xfer skid plates for 40s?
cool - thanks for the info
Do you remember if the front of the muffler extended below the frame rail?
The reason I ask is that I replaced the exhaust from the header back with OEM parts and it sure seems like something is short/off/wrong part since the exhaust pipe going from the header to the muffler is sitting right about in the center of the skid plate (ie abount half the pipe extends beolow the frame rail) and if I were to bend it any lower, the back half of the system simply will not align up for mounting....
For aftermarket skid plates check www.ironpigoffroad.com, they sell a very heavy duty skid plate for I believe $325, which seems like a pretty fair price.
