.gonna run the flex joint vertically right below the outlet on the turbo then turn it toward the rear and try to squeeze a 3" down the inside of the passenger frame rail .
I'm thinking by this afternoon I'll be coating that area in soot .
She is whistling quite nicely . Turned up the fuel about 2.5 turns . The boost maxes out about 12 psi not sure about egt's yet (haven't got the pyro hooked up) tomorrow I'll know . Holy s*** does it pull now . Super excited to try it up to washington to see the mileage and how it pulls up the hill . I think I can probably go to 37" tires and still be fine pulling up grades . I'll take a bunch of pics tomorrow in the daylight .
With out re gearing, it may be a 4th gear rig on 37s.
It is re-geared to 4.88 not sure what you mean by 4th gear rig ? It hauls ass in 5th up hills right now .
Boost seems low. Is the waste gate opening?
The only reason I say is because others with 2.5 turns are seeing boost in the 20's. I'm at less than a turn (7/8 or so) and can raise 14lbs.
Well , had a few leaks at the base of the turbo . (now sealed ) Making a constant 5lbs at highway speed and can get it to 10 easily . Gets up to 1100 degrees max on big hills . Had it up to washington a few times now . Decided to get some 37's . Got a set yesterday . The testing continues . Wheels really well (with the exception on a broken motor mount .
